Computer Specs and Need For Speed:World
51 replies to this topic
#41 ZTR
    The Legendary Freeloader
  • 6,241 posts
  • LocationMumbai,India
  • Autolog:Zakitheracer
  • Origin:Zakitheracer
  • Steam:Zakitheracer
  • World Handle:Zakitheracer
Posted 06 May 2012 - 04:56 PM
View PostSkyTails, on 06 May 2012 - 12:01 PM, said:
What's your CPU? ^_^
Phenom II X4 955 BE 3.2 GHz ^_^
''The Greatest Pleasure In Life Is Doing What People Say You Cannot Do.''
''The Stats lie and tell the truth at the same time.....''
Follow Me on Twitter!@Zakitheracer
#42 SkyTails
    Mechanic
  • Members
  • 240 posts
  • LocationJohor Bahru,Johor,Malaysia
  • Origin:SkyTails
  • PSN:NEOARDI_UKPSN
  • Crew:Team Reef
  • World Handle:SKYTAILS
Posted 07 May 2012 - 03:54 AM
Cool! ^_^ Is the Athlon Overcloackable?
#43 pepo930
    Hardcore
  • 2,658 posts
  • LocationBulgaria
  • Autolog:PROTO930
  • Origin:PROTO930
  • Steam:pepo930x
  • World Handle:PEPO930Z
Posted 07 May 2012 - 06:12 AM
Almost every CPU is overclockable. You just gotta know what are you doing or you could fry it or make the system unstable.
YouTube WTF channel >CLICK<
#44 ZTR
  • 6,241 posts
Posted 07 May 2012 - 07:04 AM
^That
Although some CPUs have a unlocked multiplier which makes Overclocking realllllllyyyyy easy lol
#45 SkyTails
    Mechanic
  • Members
  • 240 posts
  • Origin:SkyTails
  • PSN:NEOARDI_UKPSN
  • Crew:Team Reef
Posted 07 May 2012 - 12:09 PM
View PostZTR, on 07 May 2012 - 07:04 AM, said:
^That
You mean, there's no need to set the FSB and the voltage manually?
Ok, *ehem* update (new specs) The PC shop...guy said that the 6670 is out of stock, and my dad replaced it with a new one, the Radeon HD 6750. So, is it ok? And if it is, tell me what FPS I will get :giggle:
#46 pepo930
    Hardcore
  • 2,658 posts
  • LocationBulgaria
  • Autolog:PROTO930
  • Origin:PROTO930
  • Steam:pepo930x
Posted 07 May 2012 - 01:11 PM
6750>6670
And about overclocking - it depend on the CPU.
Some CPUs have unlocked multipliers and some don't. You'll have to adjust the FSB on the locked ones but I think that all AMD CPUs have unlocked multipliers which makes OCing easier.
Just raise the multipliers and voltage and it should work.
But before any overclocking, download Prime95 and FurMark (And HWMonitor for temperatures) and let them both run for 10-20 minutes.
This will get your CPU and GPU at max so that you can check if the system has good cooling and if it's a good idea to overclock.
Make sure that CPU Temps are Below 70C and GPU Temps are below 95C. If they reach that temp then you'll need better cooling.
If they pass, OC the CPU and do the same test again.
#47 SkyTails
    Mechanic
  • Members
  • 240 posts
  • Origin:SkyTails
  • PSN:NEOARDI_UKPSN
  • Crew:Team Reef
Posted 07 May 2012 - 02:54 PM
View Postpepo930, on 07 May 2012 - 01:11 PM, said:
6750>6670
Oh, Thanks Pepo! ^_^ It's a very useful information
#48 ZTR
  • 6,241 posts
Posted 07 May 2012 - 02:56 PM
But remember in case of AMD CPUs dont let the temp cross 60C!
Cause the thermal limit for Athlon and Phenoms in 62C...
#49 SkyTails
    Mechanic
  • Members
  • 240 posts
  • Origin:SkyTails
  • PSN:NEOARDI_UKPSN
  • Crew:Team Reef
Posted 07 May 2012 - 03:06 PM
Right. So, I shouldn't overclock too much, huh?
#50 ZTR
  • 6,241 posts
Posted 07 May 2012 - 03:08 PM
Its not about how much you OC
Its about the cooling which you should provide for the OC...
#51 SkyTails
    Mechanic
  • Members
  • 240 posts
  • Origin:SkyTails
  • PSN:NEOARDI_UKPSN
  • Crew:Team Reef
Posted 07 May 2012 - 03:14 PM
Oh...I'll try to find a nice cooling supply Posted Image
#52 SkyTails
    Mechanic
  • Members
  • 240 posts
  • Origin:SkyTails
  • PSN:NEOARDI_UKPSN
  • Crew:Team Reef
Posted 08 May 2012 - 05:21 PM
Bought the comp. :) 40-60 FPS while on max, and 1680x1050 res ^_^ Thanks a lot guys!
