Need for speed Shift advpack.dll error
7 replies to this topic
#1 EddieLTU
    Muscle WMD
  • 1,042 posts
  • LocationKaunas,Lithuania
  • Autolog:EddieLTU
  • Origin:same as above
  • Steam:same as above 2x
  • Xbox Live:Correction: my GFWL is : EddieLTU
  • World Handle:Eddiegsideltu.Chicane:WGEddie
Posted 05 May 2012 - 03:31 AM
so ive downloaded shift and i tryed to install it but i got an error when i was trying to install visual c++ and thanks to this i got installer crashes
i got windows xp sp3 32bit
and the specs pass the requierments
i can play it only on my moms laptop :|
Edited by EddieLTU, 05 May 2012 - 03:40 AM.
#2 rcgldr
    One of the Elite
  • 826 posts
  • LocationCalifornia
Posted 05 May 2012 - 04:04 AM
You can try downloading the visual c++ redistributable directly from microsoft. Do a web search for the version shift is using (probably 2005 or 2008), then try downloading and installing that first, then try installing shift.
#3 EddieLTU
    Muscle WMD
  • 1,042 posts
  • Autolog:EddieLTU
Posted 05 May 2012 - 04:24 AM
i did this and i got same error
#4 rcgldr
    One of the Elite
  • 826 posts
Posted 05 May 2012 - 07:29 AM
Did you get the error while trying to install the visual c++ redistibutable you downloaded from microsoft, or did that work and did you get the error while trying to install shift?
#5 EddieLTU
    Muscle WMD
  • 1,042 posts
  • Autolog:EddieLTU
Posted 05 May 2012 - 08:34 AM
red text is the anwser
#6 rcgldr
    One of the Elite
  • 826 posts
Posted 05 May 2012 - 02:09 PM
View PostEddieLTU, on 05 May 2012 - 08:34 AM, said:
... failed during redistributable install ...
In this case, you should be able to get help on this from microsoft support. You didn't mention which version you tried to install, 2005 or 2008? Looking at the web page for 2005 version, it mentions you need Windows Installer 3.0 (which you probably already have).
http://www.microsoft...lang=en&id=3387
#7 pepo930
    Hardcore
  • 2,646 posts
  • LocationBulgaria
  • Autolog:PROTO930
  • Origin:PROTO930
  • Steam:pepo930x
  • World Handle:PEPO930Z
Posted 05 May 2012 - 02:23 PM
Install everything that's in this archive. It contains:
DirectX (Latest)
.NET Framework 4
MS Visual C++ 2005
MS Visual C++ 2008
MS Visual C++ 2010
http://depositfiles....files/rys8og4cm
YouTube WTF channel >CLICK<
#8 rcgldr
    One of the Elite
  • 826 posts
Posted 07 May 2012 - 03:14 PM
View Postpepo930, on 05 May 2012 - 02:23 PM, said:
... .NET Framework 4 ...
Note that after installing .net framework 4.0 or after any update for .net framework 4.0 your system may end up running slowly the first few times you reboot it due to .net framework 4.0 updating stuff in the background. You can force it to update by opening up a dos console window, using the "cd" command to get to the .net framework 4.0 directory and running ngen.exe with parameter update. The full command without using cd's to get to the directory would be:
\windows\microsoft.net\framework\v4.0.30319\ngen.exe update
When running this command, you'll see a bunch of error messages, but it's not a problem and you can ignore those error messages. Also ngen doesn't report any status on the updates that don't cause errors.
Edited by rcgldr, 07 May 2012 - 03:16 PM.
